I but a new iac sencor and ti still give me the same code p 0505 way is that
Saturday, October 16th, 2010 AT 3:59 PM
KHLOW2008
MECHANIC
Hi willie8989,
When trouble codes are present, it does not necessarily mean a component is faulty. It could be bad wiring circuits, faulty PCM or the component is faulty.
Since you have replaced the component, the next thing you need to do is to test/check the wire circuitry and lastly the PCM if wiring does not show any fault.
