Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mitsubishi
Eclipse
Engine
Symptoms
Misfire
2000 Mitsubishi Eclipse cylinder 2 misfire
2000 MITSUBISHI ECLIPSE
144,000 MILES • 4 CYL • 2WD • MANUAL
GARYJOE_63
MEMBER
1 POST
diagnostic code says cylinder 2 misfire. could this be the coil and if so why is it not cylinders 1 and 2.what else could it be
Mar 7, 2009 at 12:55 AM
BLACKOP555
Experienced Mechanic
take and switch teh spark plug and wires with #2 with another cyliinder, does the problem move with teh old plug and wire?
if that isnt it it may be a issue with the fuel injector. and if that isnt it check the compression on that cylinder.
Mar 7, 2009 at 2:55 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
