2000 Mitsubishi Eclipse clutch
90,000 MILES • 4 CYL • FWD • MANUAL
RAYBURN.MOYE
Clutch is slipping (sulfer smell, engin seems to rev up without speeding up affer changing gears. Can this clutch be adjusted or do I need to replace?
how much $$ does a clutch kit cost these days?
Mar 2, 2009 at 1:35 PM
  • 31,937 POSTS
HI there the clutch kit will be in the order of about $250.00 labour for this job is around 5 Hrs, you will also need to get the fly wheel machined & allow for the replacement of transmission oil as this will be lost. you should check your local labour rate, and parts will vary depending on quality.
Mark (mhpautos)
Mar 2, 2009 at 6:51 PM
