2000 Mitsubishi Eclipse CHECK ENGINE LIGHT
12,000 MILES • 4 CYL • FWD • MANUAL
STEHLIK
MY ECLIPSE HAS 120,000 MILES, MANUAL TRANSMISSION AND HAS RECENTLY STARTED TO WANT TO DIE WHEN IM IN NEUTRAL OR COMING TO A STOP. WHEN I SHIFT GEARS ITS HESITANT TO INCREASE SPEED, AS IF IM IN TO HIGH OF A GEAR OR SOMETHING. THIS HAS LASTED FOR ONLY ABOUT 5 DAYS AND NOW CHECK ENGINE LIGHT IS ON. CHANGED SPARK PLUGS NOT EVEN A YEAR AGO. DO YOU KNOW WHAT COULD BE GOING ON?
Jul 15, 2008 at 4:33 PM
  • 31,937 POSTS
Hi there,
Start with having a scan done to determine what has caused the set fault code, this may point you in the right direction for you initial problem. Start here.
Mark (mhpautos)
Jul 15, 2008 at 6:08 PM
