2000 Mitsubishi Eclipse car wont turn on
125,000 MILES • 4 CYL • 2WD • AUTOMATIC
CUBANPIMP239
i just installed a new short ram intake in my car and then a few days later i was acceleraring pretty fast down the highway and out of now where the car turns of. as i tryed to turn it on agin it makes a reving noise but it dosent turn on
Jul 25, 2010 at 3:36 PM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jul 25, 2010 at 3:49 PM
