2000 Mitsubishi Eclipse Bad Gas??
155,000 MILES • 6 CYL • FWD • AUTOMATIC
KRISTAGAIL
What are the signs of bad gas? My car ran fine and has never had problems until yesterday afternoon. I stopped and filled up on the way home and my car was acting up before I even made it out of the stations parking lot. My car was acting like it wasn't getting any gas even with me pushing the gas pedal it was sputtering really bad and when it finally got some gas to it, it ran fine and I made it home. When I got home I turned the car off and let it sit for a few minutes and went to start it back up and it was sluggish starting still like it wasn't getting any gas and when I would push the accelerator it would start acting up and would act like it was going to die and then it would take the gas and run fine. What could this be? Did I get bad gas or could this be something else? What should I do? Thank you for your help!
Aug 13, 2010 at 2:49 AM
KHLOW2008
  • 41,812 POSTS
Hi kristagail,
Symptoms mentioned are signs of bad gas. Drain out the gas and refill with known good gas and retest.
Aug 13, 2010 at 9:46 AM
