2000 Mitsubishi Eclipse alternator
2000 MITSUBISHI ECLIPSE
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
OTERO713
I am trying to replace my alternator and i removed all the bolts like the computer says to but the pivot bolt hits the frame of the car
i dont know what to do and im very close to giving up... please help me....
May 7, 2009 at 9:55 AM
MONTY STEPHENS
  • 79 POSTS
That's why I always appreciate the pros -- they deal with theis stuff everyday and earn every nickel they get...
Don't give up, you almost got it, but you do have more bolts to remove. Start by jacking it up and taking your wheel off and the splash guard in the fender wheel, working through that tiny hole you'll be able to take off/loosen the bolts that hold the bracket --its got to either come off or jget real loose. You may need to take the top motor mount off also and maybe the dipstick (you can work around that though), doing that will give you more room and let you see the bolts that need to come off..
May 7, 2009 at 12:45 PM
