1999 Mitsubishi Eclipse transmission
NINESMOM
Transmission problem
1999 Mitsubishi Eclipse Front Wheel Drive Manual
where is the fluid plug on a manuel transmission to put more fluid in i found one site that said on the side But I need to know what side
Jul 1, 2009 at 1:38 PM
GRAYTA
  • 13 POSTS
The fill plug is on the back side of the tranny about half way up. Mine has a square fitting on the end to put a wrench on. You just fill it til some leaks out and then you are full enough.
Jul 20, 2009 at 6:16 AM
