1999 Mitsubishi Eclipse Only First Gear works
113,000 MILES • 4 CYL • FWD • AUTOMATIC
BRC3
The car moves in first gear just fine, no slipping and plenty of torque. As soon as it tries to shift to 2nd it slips like crazy and even first stops working and starts slipping. I don't even know where to start. thanks in advance for your time.
Aug 10, 2010 at 8:28 AM
  • 75,988 POSTS
Check and test the TPS and VSS sensors if okay-its coming from the transmission could be a valve body/shift solenoids-etc, get it pressure tested
Aug 10, 2010 at 9:24 AM
