1999 Mitsubishi Eclipse my 1999 mitsubishi eclipse starts t
ROBBIE3234
Shakes or Wobbles problem
1999 Mitsubishi Eclipse 4 cyl Front Wheel Drive Automatic 133k miles
i just bought an eclipse like 2 days ago. it has two problems. at around 45 mph it starts to shake. Ive been told it could be a broken belt in one or more tires. going to have all tires replaced today. The other problem is to do with the engine. the car ran fine, but now its stalled on me at a red light a few times, and isnt producing near the power it should be. Its hard for it to push 80. I had a computer ran on it at autozone. they said it could be the egr valve. could this be the problem. If it turns out to be the computer. about how much am i looking to pay? Thank you for your help in advance.
Jul 16, 2009 at 11:08 PM
DIRTRIDERDRUM
since you had your tires replaced if it still shakes or wobbles then check the alignment, if it is out get it replaced cause that can eat your tires, and if your computer went the car wouldnt run at all.
Aug 5, 2009 at 12:54 PM
CHRIS09323
  • 14 POSTS
i had the same problem and the problem was the break disks , when u break suddently and or hard,the break disk tend to bend so , i got the break disk turned , this will cost u like 10 each or is better if u get some good disks cause the stock ones bend real easy
Aug 5, 2009 at 2:39 PM
