1999 Mitsubishi Eclipse Misfire Codes
144,000 MILES • 4 CYL • 2WD • MANUAL
RFRANCO
'99 Mitsubishi Eclipse GS Manual transmission, engine rebuilt about 1,000 miles ago. Service Engine Soon keeps turning on with codes:
# P0300 Random/Multiple Cylinder Misfire Detected
# P0301 Cylinder 1 Misfire Detected
# P0302 Cylinder 2 Misfire Detected
# P0303 Cylinder 3 Misfire Detected
# P0304 Cylinder 4 Misfire Detected
Engine idles and runs fine. No feeling of misfiring. The only out of the normal thing is that engine sputters for a second when shutting off, but it's always done it since i got the car. Replaced coil pack, spark plugs, egr valve, air flow sensor...gone down the list of all possible causes.
Is this a case of a bad ECU?
Oct 31, 2010 at 11:03 PM
WRENCHTECH
  • 20,760 POSTS
I would guess that you have some type of issue with the assembly of the engine, possibly with valve timing or injector wiring.
Nov 1, 2010 at 12:15 AM
RFRANCO
[quote:e8307cdabc="Wrenchtech"]I would guess that you have some type of issue with the assembly of the engine, possibly with valve timing or injector wiring.[/quote:e8307cdabc]
If it was a valve timing issue or injector wiring, wouldn't it be felt on the performance of the vehicle when driving it? The car runs like new...
Nov 1, 2010 at 5:48 AM
WRENCHTECH
  • 20,760 POSTS
Not according to the computer. The computer says it's misfiring
Nov 1, 2010 at 6:22 AM
RFRANCO
[quote:fe07df07eb="Wrenchtech"]Not according to the computer. The computer says it's misfiring[/quote:fe07df07eb]
What are the chances the ECU went bad?
Nov 1, 2010 at 6:23 AM
WRENCHTECH
  • 20,760 POSTS
It's always a possibility but I wouldn't jump to that conclusion. You really should get it professionally diagnosed.
Nov 1, 2010 at 6:26 AM
