Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mitsubishi
Eclipse
Engine
Symptoms
Idle High
1999 Mitsubishi Eclipse iddle high
1999 MITSUBISHI ECLIPSE
110,000 MILES • 4 CYL • FWD • MANUAL
LEVAN1968
MEMBER
1 POST
my iddle is high around 2200 rpm
Jun 19, 2008 at 3:25 AM
KHLOW2008
Experienced Mechanic
Hi levan1968,
If the rpm stays at 2200 after the engine has warmed, you need to check for vacumn leakage after the throttle valves.
It could be a stuck ISC at throttle body.
Jun 21, 2008 at 10:36 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
