1999 Mitsubishi Eclipse had low transmission fluid
10,900 MILES • 4 CYL • FWD • AUTOMATIC
ECLIPSE310
i had low transmission fluid and i refilled it cuz my tranny was sliiping or wouldnt change gears...i filled it and it ran smooth for like 20 mins then it tugged and the same thing happen all over and my check engine light came on..wat could be the problem
Oct 27, 2008 at 4:16 PM
  • 31,937 POSTS
Hi there,
You will need to get a scan done to check the code, and a visit to a transmission specialist would be a good idea as he will need to run some tests to see where your problem lies, get this done soon, just in case you are doing damage to the transmission.
Mark (mhpautos)
Oct 27, 2008 at 4:31 PM
