99 mitsubishi eclipse, 2.0, non-turbo, manual transmission, 238,000 miles, have owned it since new and taken very good care of it. Intermittent missing problem. Sometimes the check engine light flashes on and off, but I feel no engine miss at all. Other times it misses badly, but then stops after I pull over. Sometimes the check engine light stays on, other times it does not. I have changed the plugs and wires twice. A shop replaced the coil twice. I was told it might be the ECM. I bought a used ECM and put it in myself, but the problem immediately continued. I've never changed the rings or head gasket. Trying to decide if it's worth it to keep spending money, or bail to a new car. Thanks!
Jun 3, 2008 at 2:42 AM
