1999 Mitsubishi Eclipse car overheats
124,000 MILES • 4 CYL • FWD • MANUAL
MOMAN555
My car overheats...The car starts out normal and eventually heats up so the gauge starts to slightly increase but then the fan turns on and it goes back down to the normal. Eventually the fan turns off and the needle starts rising again and then the fan turns on. But slowly it doesn't stay at the middle anymore, it gets elevated to the top. I dont know what the problem is...radiator,water pump, or heater core...can you help?thank you
Apr 15, 2010 at 11:10 AM
KHLOW2008
  • 41,812 POSTS
Hi moman555,
Did you check the coolant level in the radiator?
Symptoms indicates possible coolant shortage.
Apr 21, 2010 at 3:15 AM
MOMAN555
it was low before and it just overheated no going up and down...then when i added water, it started going up and down...so maybe there is a leak somewhere...but what parts of the system could be leaking?i know the radiator can be but what about the water pump...i think the hoses are fine...?but the water pump?thank you...
Apr 22, 2010 at 3:54 AM
KHLOW2008
  • 41,812 POSTS
When coolant level drops, topping up is not sufficient. You need to let it run for a while with the radiator cap off to bleed the system and keep topping up till the level maintains.
When minor leaks occurs, it seldom are the hoses. It could be joints, water pump etc. A pressure test would enable you to locate the source of the leak.
Apr 22, 2010 at 4:01 AM
