I will certainly try that first thing in the morning (about 50 miles from the car right now). Also I checked the Fuel Pump Relay nd the ASD. The fuel pump relay cheked fine. The asd was a litte different. I did a voltage test. From 4-6 I get 10.2 volts and from 2-8 I get the 12 volts. Thats only on the ASD relay. On the fuel pump relay, I get 12 volts from 2-8 and 0 volts from 4-6.
I am now thinking about driving to the car to test your suggestion I am anxious to see if that works.
Lastly, on the 3 leads on the coil which one is positive? I cannot find that info, not even in the book.
Thanks,
Scott
Tuesday, October 14th, 2008 AT 6:20 PM
