1999 Mitsubishi Eclipse
143,000 MILES • 4 CYL • FWD • MANUAL
99ECLIPSE420A
1999 eclipse rs, with the 420a, its stock other than exhaust and cold air intake, i replaced the clutch and pressure plate, then afterwards it started idling at anywhere from 2500 to 4000 rpm's, it did this before but not nearly as bad, also, its not a steady idle, it will go up and down on its own, and sometimes if i tap the throttle, it will go down to about 1500 and go back up, i dont have an O2 sensor, but the problem started long after that was gone, thanks for any help
Apr 16, 2010 at 7:36 PM
KHLOW2008
  • 41,812 POSTS
Hi 99eclipse420a,
I believe the Idle Air Control ( IAC) valve is faulty or sticking causing the high idling.
Apr 21, 2010 at 3:26 AM
