Engine Cooling problem
1999 Mitsubishi Eclipse 4 cyl Front Wheel Drive Automatic
Are all mitsubishi bolts too long? The bracket for the front or pass side engine mount has two bolts that no matter how much I raise or lower the engine, will not slide out. I'm trying to get to the water pump & timing belt. Does the engine have to come out? This design is similar to the Neon which has barely enough room for the bolts to slide out when you get the engine in the right position. Help!!!
Jul 17, 2008 at 5:14 PM
