1998 Mitsubishi Eclipse will not go in gear fluid is full t
YOSH250
Transmission problem
1998 Mitsubishi Eclipse 4 cyl Front Wheel Drive Manual 12.000 miles
it will no go in gear fluid is full slave is moving think it is a preasure plate is no good
Nov 7, 2010 at 11:38 PM
KHLOW2008
  • 41,812 POSTS
Hi yosh250,
It could be the pressure plate or disc. When the damping spring or rubber are faulty, the can drop out and cause the plate to be stuck.
If the hydraulic system is confirmed to be good, you have no alternative but to remove the trans to replace the clutch.
Nov 8, 2010 at 3:10 AM
