1998 Mitsubishi Eclipse timing belt tensioner
1998 MITSUBISHI ECLIPSE
12,000 MILES • 4 CYL • 2WD • MANUAL
DRGUITARDUDE
I had a broken timing belt replaced, along with valve repair, then two days later the timing belt jumped again because the bolt holding the tensioner broke. My local mechanic said it looked like the tensioner was pushed too far forward, but the mechanic who did the work said that is impossible because it auto-adjusts. Who is correct? Where can I find that information in print?
Jan 23, 2008 at 1:36 AM
PUREORNERY
im not sure about on the 98 models but on the 92 plymouth laser (same car) i have to adjust it myself it is not a "self adjusting tensioner" like on the typical serpentine belts. Hope this helps.
[quote:aa15739911="drguitardude"]Engine problem
1998 Mitsubishi Eclipse 4 cyl Two Wheel Drive Manual 120,00 miles
I had a broken timing belt replaced, along with valve repair, then two days later the timing belt jumped again because the bolt holding the tensioner broke. My local mechanic said it looked like the tensioner was pushed too far forward, but the mechanic who did the work said that is impossible because it auto-adjusts. Who is correct? Where can I find that information in print?[/quote:aa15739911]
Jan 23, 2008 at 2:23 AM
2CARPRO JACK
  • 11,533 POSTS
If it was a single bolt that broke it has the mechanical tensioner not the hydraulic that self adjusts. Could be the spring was weak in the tensioner causing it to let the belt slap it and break the bolt.
Jan 23, 2008 at 11:47 PM
