1998 Mitsubishi Eclipse System Rich
132,020 MILES • 4 CYL • FWD • AUTOMATIC
ITCHWEEED2000
I scanned my car for codes, and a code came up "SYSTEM TOO RICH (Bank 1)". My question is what could cause my car to run rich? Mind you, I did tune up...changed plugs, wires, coil...then I scanned system...please help me out...
thank you
Feb 16, 2010 at 9:30 AM
  • 75,988 POSTS
Your possibilities here could be one of the following, O2 sensor, fuel pressure regulator, leaking injector/s, cloged airfilter and coolant temperature sensor stuck in the open loop mode-
Feb 16, 2010 at 9:47 AM
