1998 Mitsubishi Eclipse oil leak
1998 MITSUBISHI ECLIPSE
105,000 MILES • 4 CYL • FWD • MANUAL
MENKZ
im having an oil leak..
i dont know where its coming from but definitely not from valve cover. im sure its underneath.
whats the best thing to do or where to check?
Jan 9, 2008 at 9:17 AM
  • 31,937 POSTS
Hi there,
Wash the motor down and check after a day or so, that will make identifying the leaks a bit easier, If it is still to messy, wash and run engine , you may see the leak develop before it gets to messy again to identify.
Mark (mhpautos)
Jan 9, 2008 at 9:23 AM
NO REGRET
  • 5 POSTS
if you still cant find it try using dye u can get it of any tool truck and local auto parts stores u will definatly find it then
Jan 9, 2008 at 1:56 PM
