1998 Mitsubishi Eclipse No engine compression in engine
18,600 MILES • 4 CYL • 2WD • AUTOMATIC
IONETREK
My water pump locked up and tore the timing belt. I replaced the timiming belt, but the engine runs very rough. It will not stay running by itself. I have opened the timing again to check the timing. I got an engine compression gauge and hooked it up to the spark plug openings. 3 cylinders did not show any compression at all. the 4th cylinder showed 30 lbs of preessure. What does this indicate?
Jul 30, 2010 at 7:45 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Engine is an interference engine which means whem T belt brakes pistons hit and bend valves. Will nee to remove head and replace bent valves. wish I had better news
Thanks for donate
Jul 30, 2010 at 8:05 AM
