Engine Performance problem
1998 Mitsubishi Eclipse 4 cyl Two Wheel Drive Automatic
i do have a car and the problem that is causing is every time that i make an stop the rpm goes all the way down seem like it will turn off the engine, nasty smog and odor is release after that then the rpm goes to normal again but still smog comming out
does any body know please help
Apr 17, 2009 at 1:53 PM
