1998 Mitsubishi Eclipse Door Locks
101,000 MILES • 4 CYL • FWD • AUTOMATIC
CLINT G
Pass side door handle was replaced due to a attemted breakin .(Bad guy used slim jim + snapped handle) Since replacement ,door locks will only work manually.
Oct 11, 2009 at 5:27 AM
KHLOW2008
  • 41,812 POSTS
Hi Clint,
Thank you for the donation.
During replacement of the door handle, the wiring connector could have been dislodged or not connected. Another possibility is the slim jim action had broken the door lock wires.
You would have to remove the door panel to have a look at the wires and connectors. If the locking motor is working while operating the door locks control, the door lock linkage could have been dislodged or the clips broken.
Oct 12, 2009 at 4:05 AM
CLINT G
[quote:e9c25ef014="KHLow2008"]Hi Clint,
You would have to remove the door panel to have a look at the wires and connectors. If the locking motor is working while operating the door locks control, the door lock linkage could have been dislodged or the clips broken.[/quote:e9c25ef014]
Oct 13, 2009 at 12:04 PM
