My eclipse was misfirring earlier today on the express way, like all of a sudden the speedometer went from 60 to 0 and the revs per min were moving up and down. I took it to a shop to do a diagnostics and it said it was misfirng and that the crank shaft sensor is not working properly. Once I got home I tried to turn it on and nothing happens. The battery is fully charged but no crank. I needed help to see what the problem might be. Can anyone help?
And now today the check engine light is not on but it does not crank or anything? DOES not want to turn on.
SPONSORED LINKS
Saturday, September 27th, 2008 AT 12:22 AM
MECHANIC
Load test the battery if it checks out-make sure its cleaned/properly tightened. No problem on battery side.
Check fusible link no. 4 30Amp, ignition switch, starter relay, transaxle range switch and starter itself.
