1998 Mitsubishi Eclipse Clutch Damper Clutch Master and Sla
80,600 MILES • 4 CYL • FWD • MANUAL
ARMANDOZAMORANO
  • 6 POSTS
deperate for help, replaced master clutch cylinder, than replaced slave master cylinder, even after bleeding system, the clutch pedal will eventually in a couple of minutes hit the bottom, will replacing the clutch damper help, what is its purpose, can it be bypassed, and what else could be causing this problem....perplexed and frustrated by problem.
Nov 5, 2009 at 12:13 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
The clutch damper is just a device that helps remove any shock loading from the hydraulic system, i have never known of one to give this problem, but there is alway the first time... I would be more inclined to suspect that the new master is faulty, this dose happen, the hydraulic system is very basic, the master displaces fluid the moves the slave piston, if there is a leak in the slave it will be wet under the boot, if the master is by-passing internally, the piston will drop as fluid by pases the pressure seal with out any external leakage.
Mark (mhpautos)
Nov 6, 2009 at 11:05 AM
ARMANDOZAMORANO
  • 6 POSTS
i just need to know the reprocusions that i might have if any if i bybass or eliminate the clutch damper......
Nov 7, 2009 at 8:55 PM
  • 31,937 POSTS
I don't think that there will be any, i have not done this myself, but just considering the system, i don't think that if anything you may a slightly different feel in the pedal, but the pressure and through should be the same.
mark (mhpautos)
Nov 7, 2009 at 9:19 PM
  • 31,937 POSTS
Hi there,
Thank you for the great feedback, did you bypass the damper? what effect did it have on the feel of the clutch and did it help with your initial problem.
Mark (mhpautos)
Nov 10, 2009 at 7:18 AM
ARMANDOZAMORANO
  • 6 POSTS
yes i have bypassed it, but you were right about the initial problem, it is still the same as before, so i will put a new master clutch cylinder in and leave the damper bypassed..and see how that works. Thanks
Mark (mhpautos)[/quote]
Nov 11, 2009 at 10:11 AM
