1998 Mitsubishi Eclipse car turns on and off
CHRIS09323
  • 1998 MITSUBISHI ECLIPSE
  • 4 CYL
  • FWD
  • MANUAL
  • 130,000 MILES
Car turns on an off real quick if I try restarting it right away it will just turn but not start I have to wait for like a min then it will start but dye again
Tuesday, August 18th, 2009 AT 12:49 AM
Check the fuel pressure and report back with the readings this is where we start
Tuesday, August 18th, 2009 AT 12:56 AM
CHRIS09323
  • 14 POSTS
There is fuel pressure, just in case I checked the fuel pump and is working
Tuesday, August 18th, 2009 AT 1:03 AM
Use starting fluid thru the throttle body if it fires up and stalls-again I ask you to check the fuel pressure could be low EFI system don't like low pressure and then report back.
Tuesday, August 18th, 2009 AT 1:09 AM
CHRIS09323
  • 14 POSTS
I used the fluid but it just made a sound like it didnt want to turn on, then it turned on but it shut of again
Tuesday, August 18th, 2009 AT 9:10 PM
Check the fuel pressure and come back with the readings
Tuesday, August 18th, 2009 AT 9:48 PM
CHRIS09323
  • 14 POSTS
Will I need to bring a mechanic for the fuel pressure or can I do it my self, also somebody told me it was the memory, note when I checked my alternator the positive cord was all burned I think I had a short there the positive was touching the negative, they said that probably burned my memory
Sunday, August 30th, 2009 AT 10:59 PM
