1998 Mitsubishi Eclipse Break Lights
YAKOZUMA
Electrical problem
1998 Mitsubishi Eclipse 4 cyl Front Wheel Drive Manual
Hi, a few days ago my break lights stopped working. All the other lights work, there are no blown fuses, I've checked the relays they are fine. I've been thinking that it might be the flasher, but when I went to Auto Zone they sold me a flasher with a 3 way-in that I couldn't fit in any of the flashers that I would take out. And they said that that flasher would work. I need some help as to why my break lights aren't working and my hazard lights have stopped working as well. thanks
Jun 5, 2010 at 11:02 AM
  • 75,988 POSTS
You need to check the brake switch follow the brake pedal arm till it meets the brake support bracket the switch is here.
Jun 5, 2010 at 1:14 PM
YAKOZUMA
Alright will do, and any idea what might be wrong with my hazards not working?
Jun 5, 2010 at 1:18 PM
  • 75,988 POSTS
Check the fuse and also the flasher unit
Jun 5, 2010 at 2:15 PM
