I just recently replaced my battery with a Red Top, Optima. I installed a 12'' 2400 watt sub, my amp is only giving the subwoofer between 400-700 RMS watts. I installed the remote wire correctly in the headunit but everytime i go to start the car it seems as if the amp drained the battery. Now that i disconnected my system its still having problems, could this be the alternator? if it is for this system wat amp rating should i get on an alternator? is a 90 amp good? sry for the long question!!!!!
Jun 23, 2008 at 2:20 PM
