1998 Mitsubishi Eclipse
146,000 MILES • 4 CYL • 2WD • AUTOMATIC
JWRHINE
I have a 1998 Mitsubishi Eclipse that just got the timing belt replaced, do to it snapping. I got a compression test ran on the cylinders & the 2nd cylinder is reading 0 lbs. Would i be able to drive it up to 20-25 miles to get it home; that way i can have a friend, take apart & rebuild the head, because only 3 cylinders are running.
Feb 17, 2009 at 12:23 PM
BLUELIGHTNIN6
  • 16,542 POSTS
It's pretty hard to do on a 4cylinder engine.. If it can start up then it can drive. You just won't be able to go very fast at all. It will be a lot of stress on the engine as well.
Thanks for using 2CarPros.com!
Feb 17, 2009 at 3:04 PM
