1998 Mitsubishi Eclipse
WALTCOOL5
Engine Mechanical problem
1998 Mitsubishi Eclipse 4 cyl Two Wheel Drive Manual
put a new motor in, started first time i tried, then it cut off, getting spark & fuel, changed out the crankshaft sensor.and the computer. there is air coming out of the valve cover, and it should be sucking in air. I'm going to change out the camshaft sensor next.I need some help so please help me if you can. air is coming out where it hooks up to the air filter............
THANK YOU walt
Apr 26, 2008 at 3:25 PM
  • 31,937 POSTS
Hi there,
Pleases explain what you mean by air coming out of the valve cover, is there air pressure when you remover the filler cap?
mark (mhpautos)
Apr 26, 2008 at 3:29 PM
