1997 Mitsubishi Eclipse turbo
150,000 MILES • 4 CYL • 2WD • MANUAL
HITMAN1968
top speed is 30 mph, injectors were checked,155 across the board on compression. changed the maf sensor. is the turbo is bad, will it cause the problem?
Oct 15, 2009 at 2:53 AM
BMASON99
  • 5 POSTS
Check all intake lines, a intercooler line leaking could cause this.
Nov 30, 2009 at 5:56 AM
