1997 Mitsubishi Eclipse Throttle Position Sensor
136,000 MILES • 4 CYL • FWD • MANUAL
CLEBROWNS88
Hello, I have a throttle position sensor that is not working properly i believe and makes my engine run awful, it seems flooded, idles very high and the throttle response is slow. but on the other hand sometimes it works perfect, car idles at 800 RPM and throttle response is quick... sometimes i cant even start my car because it seems flooded because the throttle sensor is wacked up. I have a minor exhaust leak but i dont think it is causing any of this. sometimes my car runs and idles perfect, other times it runs awful, you can smell gas or fumes of somesort, and chokes when you hit the gas. I bought a "used" throttle position sensor to try to fix the problem and it did not help. i replaced the plug end and wires and that didnt really help much either. and if i buy a brand new one and my car still runs like that i dont know what to do next! replace the whole throttle body?? but the car runs perfect sometimes, i know its something thats relatively easy and common sense, i just cant figure it out. we tried to test the sensor with the multi meter and couldnt get anby readings from the multimeter... like the tps wasnt even putting out a signal... please help!!
Jan 19, 2010 at 3:31 PM
SHADOW4690
it could be the ecm not putting out a signal!
Jan 21, 2010 at 9:19 AM
