I have been having problem with the transmission's overdrive not staying engaged. I had started the car and was driving out of the parking lot when the engine died and the car came to an abrupt stop. The car will turn over but it seems labored and it will not start. I tested for lack of fuel by using starter fluid and it seems as if there is no spark. What could this be and what should I check next? I should ad that the Throttle Position Sensor is bad ( I checked it with my multimeter and the resistance never changes) and that the transmission, although going bad, shifts through the three primary gears fine. I also checked the timing belt and it seems to be fine with no obvious damage and rolls along as the engine turns over. The engine is a 2.4 SOHC 4 cylinder
Feb 24, 2010 at 8:45 AM
