1997 Mitsubishi Eclipse radiator
DANIELAYON14
  • 1997 MITSUBISHI ECLIPSE
  • 4 CYL
  • MANUAL
  • 106,000 MILES
My car keeps over heating, I repalced the radiator and it keeps over heating, could it be the censor or the thermastat?
Tuesday, February 24th, 2009 AT 8:02 PM
ZACKMAN
  • 4,202 POSTS
Did you replace the radiator because it was leaking or because the overheating problem? You should have start with the simplest and the least expensive items first, which would have been the thermostat, and then the engine coolant temp sensor.
Do happen to see the coolant reservoir boiling as soon as the engine is turned off? You may also want to replace your radiator cap, just for a good measure.
Wednesday, February 25th, 2009 AT 12:49 AM
