1997 Mitsubishi Eclipse OIL PUMP
112,000 MILES • 4 CYL • 2WD • AUTOMATIC
DESTINYL
My oil pump locked up on my engine its a 2.0 turbo and i need to replace the oil pump, timing belt, and srive shaft belt. My Question is ( Is there a way to replace these things without having to take the whole motor out?
Sep 8, 2010 at 1:19 AM
HORIZONTALKEV
You can change the oil pump by just dropping the oil pan i believe.
Sep 28, 2010 at 2:05 PM
