I have a 1997 Mitsubishi Eclipse DOHC 2.0L NA model. The car would shut off at high speeds and the instrument panel would go completely dead. After this happened I was able to turn off the key, wait about 30 seconds, and the car would start right back up again. I have been driving the vehicle off and on in an attempt to diagnose the issue myself, since the 3 trips to the Mitsubishi dealership turned up nothing. A few days ago this happened again, but the car will no longer start at all.
On checking for fuel pressure, I noticed that the pressure in the fuel rail was low. This was corrected by replacing the fuel filter but the car still did not start. I pulled a plug and discovered that they are not igniting.
First I checked the timing belt. The belt looks new, appears to have the appropriate tension, and there is nothing to indicate that it has jumped.
Next I replaced the CAM position sensor. Still no spark.
Finally I replaced the Crank position sensor. No change.
At this point I am assuming that it can only be 1 of 3 things.
I may have to replace the timing belt, the coil pack could be bad, or finally the computer may be fried. I sincerely hope that it is not the latter, as they are very expensive to replace.
Any suggestions? I would love to find a way to test the coil pack to identify or eliminate it from the equation. Unfortunately I was laid off recently and have blown all my money on sensors. Any help would be appreciated.
Oct 7, 2009 at 7:45 AM
