1997 Mitsubishi Eclipse MY CAR IS DYING
131,000 MILES • 4 CYL • FWD • AUTOMATIC
ALLEYALSN
my 97 eclipse keeps shutting off on me while driving it.
i can give it gas going up and hill and it will shut off sometimes or while it is setting.
i dont know whats wrong with it. i have tried and tried to find it but it could be a million things.
can you help me??? PLEASE
Jul 19, 2008 at 1:50 AM
KHLOW2008
  • 41,812 POSTS
Hi Alleyalsn,
So with a million possibilities where do we start?
What have you done so far?
Can you give a better description of the symptoms?
Is idling ok?
Is the Check Engine light showing?
Jul 20, 2008 at 5:43 AM
ALLEYALSN
the only thing that i can u is that my dad cleaned somthing out of a pipe and it still didnt work.
the car just dies on me.. and its hard to start back... i think when it tries to die i give it gas and it floods it..
my cel comes on sometimes but not when its dies.. so i dont know what to do
Jul 20, 2008 at 10:07 AM
KHLOW2008
  • 41,812 POSTS
Hi Alleyalsn,
When the CEL shows, it means something is not working correctly and it might be the cause of the problem.
Get a free scan done at Autozone and come back with the code so that we can understand your problem better.
Jul 20, 2008 at 11:57 PM
CHERYL LAWRENCE
  • 6 POSTS
I also have a 1997 mitsu and that happened to me for a while too. That is, right up until a plethora of problems came up. So heres a few questions for you: Are your spark plugs and wires working correctly and do you ever hear a "pop" when your driving like you ran something over? Are you loosing oil or overheating frequently? (There's this tiny length of hose that has a tendency to get a hole in it. Cheap fix if you catch it early) And when was the last time you replaced your timing belt? I pray for your sake its not the timing belt. If that baby snaps might as well call your car totaled. Mitsu's arn't non interference so if that belt snaps you're going to do ALL sorts of damage.
Jul 21, 2008 at 5:57 PM
