1997 Mitsubishi Eclipse Miss-Firing
145,000 MILES • 4 CYL • FWD • MANUAL
XIPHOID
Some time ago my eclipse started miss-firing. Cylinders 1 and 3 as the code reads are miss-firing. im not sure where the problem is coming from though. I have replaced the plugs and wires recently so its not that. I took it to a mechanic and he said it was the head gasket but that is hard to believe because its not leaking any coolant nor is it over heating at all. another symptom is a bad oil leak which the mechanic blamed on the head gasket as well but if it were leaking that much it it would be leaking coolant too. I looked in to the electronic distributer but it is paired with cylinders 1 and 4 together and cylinders 2 and 3 togeter so its not that or more or the would be miss-firing. if some one could get back to me with an answer asap i would appreciate it.
Apr 22, 2009 at 2:00 PM
MONTY STEPHENS
  • 79 POSTS
Try some dieletrci grease around the bottom of the spark plug boots -- it could be arcing. Happened on mine.
Apr 24, 2009 at 8:18 AM
