1997 Mitsubishi Eclipse making clacking noise then stalled,
18,800 MILES • 4 CYL • 2WD • MANUAL
BECKIE1278
2 weeks ago I had gotten an oil change, they had to put 5 quarts in and said that the timing cap is missing. today it was clacking real bad so I put 2 quarts in then drove @ 10-15 miles down the freeway, when exiting the noise gotten louder. then approx. another 5 miles while turning the corner at a stop light it stalled. now it wont even turn over. Did it throw a rod and now the whole engine needs replaced or could it possibily be something thats able to be fixed or replaced without having to spend thousands on another engine?
2
Nov 1, 2010 at 10:47 PM
KHLOW2008
  • 41,812 POSTS
Hi beckie1278,
Symptoms does not bear good tidings.
Engage 4th speed and try to push vehicle with handbrake released. If vehicle does not move with a hard push, the engine has seize and most likely a new engine is in order.
Nov 3, 2010 at 2:27 AM
