1997 Mitsubishi Eclipse making clacking noise then stalled
BECKIE1278
  • 1997 MITSUBISHI ECLIPSE
  • 4 CYL
  • MANUAL
  • 18,800 MILES
2 weeks ago I had gotten an oil change, they had to put 5 quarts in and said that the timing cap is missing. Today it was clacking real bad so I put 2 quarts in then drove @ 10-15 miles down the freeway, when exiting the noise gotten louder. Then approx. Another 5 miles while turning the corner at a stop light it stalled. Now it wont even turn over. Did it throw a rod and now the whole engine needs replaced or could it possibily be something thats able to be fixed or replaced without having to spend thousands on another engine?
2
Tuesday, November 2nd, 2010 AT 5:47 AM
KHLOW2008
  • 41,814 POSTS
Hi beckie1278,
Symptoms does not bear good tidings.
Engage 4th speed and try to push vehicle with handbrake released. If vehicle does not move with a hard push, the engine has seize and most likely a new engine is in order.
Wednesday, November 3rd, 2010 AT 9:27 AM
Related Engine Stall While Driving Content
