1997 Mitsubishi Eclipse ligths flickering
70,000 MILES • 4 CYL • 2WD • MANUAL
ED209
I have a 97 eclipse gst it is the turbo model. I recently changed the alternator and after a while my check engine light turned on. I checked with a shop and the checked the problem and said it was my idle air control valve...i am in the process of getting it changed. Now wenever i turn on my car and turn on my lights they start to flicker until my car is on for about 3 minutes. Then when i start to drive as i accelerate they start to flicker then when i keep it at a constant speed they stop flickering untill i take my foot off the accelerator or accelerate again. I just wanted to know if the idle air control could be the cause of the lights flickering or is it something else??
Feb 26, 2009 at 8:40 AM
  • 75,988 POSTS
Get the charging system checked out thoroughly
Feb 26, 2009 at 9:24 PM
