1997 Mitsubishi Eclipse harmonic balancer removal
165,000 MILES • 4 CYL • 2WD • AUTOMATIC
TYEARICKS
We already have the puller, but how do you get the harmonic balancer off using the puller without damaging the balancer?
Jul 28, 2008 at 11:21 AM
  • 75,988 POSTS
You need to remove the vibration damper center bolt-now use the correct type puller clamp it/bolted on and gradually tighten it to remove it-
Jul 28, 2008 at 10:07 PM
