TORQUE SPECIFICATIONS
Application Ft. Lbs. (N.m)
Clutch Damper Bolts 14 (19)
Engine Mount-To-Transaxle Bolts
Eclipse, Galant & Mirage
8-mm(1)
10-mm22-25 (30-34)
12-mm32-39 (43-53)
Flywheel-To-Crankshaft Bolt
Eclipse & 3000GT 55 (75)
All Others 94-101 (127-137)
Fulcrum Bolt 27 (36)
Pressure Plate-To-Flywheel Bolt 14 (19)
Release Cylinder Bolts 13 (18)
Transfer Case-To-Transaxle Bolt
3000GT64 (87)
All Others40-43 (54-58)
Wheel Lug Nuts
Eclipse & 3000GT89-103 (120-140)
All Others65-80 (88-109)
INCH Lbs. (N.m)
Clutch Booster Mounting Nuts
3000GT AWD84-108 (9.5-12.2)
Master Cylinder Mounting Nuts115 (13)
(1)Tighten to 84-108 INCH lbs. (9.5-12.2 N.m).
Apr 20, 2009 at 11:36 PM
