1997 Mitsubishi Eclipse Engine Monitors -- Smog Check
1997 MITSUBISHI ECLIPSE
95,356 MILES • 6 CYL • 2WD • AUTOMATIC
PHILIP WOGSBERG
I recently had the engine monitors reset after the "Check engine" light came on. since then I have filled the gas tank, driven in town and on freeways for about 250 miles and at lease 10 minutes at a time, cooled engine down every night for 2 weeks. Still I have about 6 control registers on the engine computer that remain not available, namely two oxygen sensors, evaporative sensor, EGR sensor, and others. My mechanic has no suggestions. How can I get these sensors to resume operation quickly? 949-831-6000.
My smog check must be completed in Dec09 or I risk a "no registration" fine.
Thanks in advance.
Dec 25, 2009 at 8:34 AM
MATHIASO
  • 1,209 POSTS
Hi Philip Wogsberg
Welcome to 2carpros.
In order to better assist you and been precise in the answer to the problem, I would like to have all the codes in form like this"p0xxx" or "p1xxx".
Thank you and see you again
Dec 26, 2009 at 4:19 AM
