1997 Mitsubishi Eclipse Dangerous RPM Problems
JRIECHERS
  • 1997 MITSUBISHI ECLIPSE
  • 4 CYL
  • FWD
  • MANUAL
  • 172,000 MILES
Symptoms:
1. When pressing in the clutch when comming to a stop the RPM will dip down to 100-200, then slowly climb back up to 700. If I give it a quick gas jab it will stay normal. Twice now it has dropped to 0, one of which was while I was not actually stopped yet so I was able to pop it in 2nd to get the engine going again.
2. This seems to happen more if the AC is on and/or engine is hot (i live in AZ). Some days it doesnt happen all.
3. Every now and then instead of RPM dropping it will surge to 1500-2000 and stay there until I come to a complete stop.
4. Ive had the oxygen sensor replaced, spark plugs and related wiring, and have had the throttle body and injectors cleaned.
5. I just noticed last night there is a small leak somewhere in the bottom of my radiator which I am replacing today.
Wednesday, August 11th, 2010 AT 11:56 AM
KHLOW2008
  • 41,814 POSTS
Hi jriechers,
Seems you have a problem with the ISC ( Idle Solenoid Control or commonly known as IAC, Idle Air Control). Check if any trouble codes are present and if none, get it cleaned. Ans check for smooth smooth movement.
Friday, August 13th, 2010 AT 4:43 PM
