1997 Mitsubishi Eclipse cooling Sensor
DEMOMANTWO
Engine Cooling problem
1997 Mitsubishi Eclipse 4 cyl Two Wheel Drive Automatic
My thermostat will sometimes register hot and then go back to normal. My radiator is fine and the car doesn't overheat. I have replace the thermostat three times now thinking that is the problem, but my brother informed me of a cooling system. Where is it?
Feb 26, 2009 at 4:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle's engine coolant temperature sensor is located on the thermostat housing, should be passenger side of engine.
Thanks for using 2CarPros.com!
Feb 26, 2009 at 8:19 AM
