1997 Mitsubishi Eclipse Clutch Problems
21,000 MILES • 4 CYL • FWD • MANUAL
DWAHRMAN
In August, the original clutch of this car went out and I replaced it. One month later, the new clutch went out, so I exchanged it thinking that it was a faulty clutch. However, one month later, I'm having to replace the clutch once again. What could be causing this?
Oct 22, 2009 at 11:39 AM
PSYCHE335
[quote:2a85fdd6ce="dwahrman"]Drive Train Axles Bearings problem
1997 Mitsubishi Eclipse 4 cyl Front Wheel Drive Manual 210,00 miles
In August, the original clutch of this car went out and I replaced it. One month later, the new clutch went out, so I exchanged it thinking that it was a faulty clutch. However, one month later, I'm having to replace the clutch once again. What could be causing this?[/quote:2a85fdd6ce]
Nov 8, 2009 at 11:10 AM
