Recently purchased used. In order to pass inspeciton catalytic converter needed to be added, along with other minor repairs.
PROBLEM: Runs intermittently rough (stutters) Check Engine light comes on when car stutters.
and goes off when running ok.
Local mechanic has worked on it and cannot diagnose exact problem, but believes it to be either fuel or electrical problem and said it will either need to get worse, or be consistant to figure out cause. Or he suggested that I take it to dealer for computer diagnostics. to pinpoint problem before it gets worse......
I don't want to put a lot more money into car--if problem is not costly to repair, I will fix, otherwise, I am inclined to get rid of car before it starts bleeding my pocketbook.
I welcome any suggestions or ideas.
I mention the catalytic converter because Car Talk said after market catalytic converters do not always work well. That is the only clue I have to go on........
Lainie K
Aug 3, 2020 at 7:57 AM
(Merged)
